Snapseed problem
(Topic created on: 06-23-2025 11:30 AM)
Pankaj7131
I never set up a work profile, and there is nothing about administrative block on my personal phone (S24 Ultra). But when using Snapseed, it shows a warning and cannot access all the photos in my gallery. Has anyone faced this problem? Does anyone know the solution?
15 Comments
Check what all admins are active in your phone and disable it if required. Then check again
Pankaj7131
I am using one admin account, and every permission is granted for the app.
Disable that as admin and then check
Pankaj7131
How to disable that? Kindly tell me the process
Search device admins in your settings you will get all the options
Pankaj7131
I find that there is only one option, "Find Hub." I disable it...But it doesn't help
Which app is that?
Pankaj7131
In the admin section, I found a "find hub," which I think is responsible for finding devices. There are no other admins in the device administrators section.
I posted about the issue with the app "Snapseed."
Not sure man, wait for others response as well. You can try restarting your phone as well as you have updated the admins
