Smart Select Edge Panel
(Topic created on: 09-18-2024 09:01 PM)
MassSaab
After updating to latest August update smart select edge panel disappeared from edge panel from my S23U.
6 Comments
Ammitz
same !
NOMAĐ
MassSaab
My s23u runs on one ui 6.1 not on 6.1.1
MassSaab
So please reply after understanding the facts
NOMAĐ
Oh then you must specify the facts right. "After updating to latest update" means its 6.1.1. Get it fact checked **bleep**. S23 received 6.1.1 and that is latest. Think clearly before asking.
Even s24 running 6.1.1 is with August patch.
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
