Small bug or problem with Vpn
(Topic created on: 06-06-2024 10:59 AM)
akshaythakur1996
Helo does anyone face with issue
I put my all apps in wifi only so that apps wont use mobile data ,only apps which i need to be used both mobile data and wifi is working when i turn on my vpn .. so basically if i turn on my vpn apps which are allowed to work with wifi and data only working not others
You can find in the setting section
ALLOWED NETWORKS FOR THE APPS
WIFI ONLY
MOBILE DATA ONLY
MOBILE DATA AND WIFI
 turning vpn on then only mobile data and wifi apps are working not others
Hope i am clear with the issue
And i have chnaged the vpns also same problem
3 Comments
Umangmathur
Nope I didn't
What
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that this is the concept of the devices, If you have other concerns regarding Samsung products kindly feel free to get in touch with us if there is any issue regarding the Samsung.
