04-28-2020 05:28 PM (Last edited 04-28-2020 05:29 PM ) in
Galaxy S- Mark as New
04-28-2020 06:00 PM in
04-28-2020 07:00 PM in
04-28-2020 06:01 PM in
Galaxy S1 use adaptive battery
2 use medium power save
3 prevent background apps from consuming data in battery device care
4 put unused apps to sleep
5 reduce some permissions given to apps that are not necessary for running of app
6 use dark mode
7 use location when necessary as in maps Google search or any location based app else constant use loads battery causing heating
8 prevent network inputs like NFC bluetooth WiFi from working together too many network inputs will cause heating and lagging
9 while charging keep phone idle
10 turn off auto sync use when necessary
11 reset phone settings once clear cache
12 if nothing works once try factory reset
13 charge in cool conditions as outside weather will be hot these days
14 dont use vibration if not necessary
15 use accubattery for complete battery diagnostics
I hope this helps because one ui bugs can be fixed by samsung when new updates come till then try these tips they could help to reduce battery heat up and loading so that smooth charging works and device runs smoothly
04-28-2020 06:30 PM (Last edited 04-28-2020 06:31 PM ) in
04-28-2020 06:58 PM in
Galaxy Scheck in safe mode
charge your phone in safe mode to see if any app is causing software glitch
04-28-2020 07:00 PM (Last edited 04-28-2020 07:00 PM ) in
Galaxy Sor u could just factory reset once
04-28-2020 08:13 PM in
04-28-2020 08:15 PM in
Galaxy Syou may contact samsung customer care and ask them
04-28-2020 09:22 PM in
Galaxy SOTA updates are first priority but if device has bug problems and u take to service center what else do they do either they flash or factory reset only 2 options based on software grounds hardware is totally different department
