Slight ding noise on s23fe vibration motor
(Topic created on: 10-06-2024 09:54 PM)
kemren
I've had the s23fe for about 3 weeks now and I noticed when using the swipe gestures on the s23fe the vibration motor makes a very light ding sound it's not really noticeable unless u try listening for it I wanna know whether that's normal cos it's been like this since I got it out the box and it doesn't affect performance of the vibration motor or anything even when doing the diagnostics test everything is fine just that slight dinging noise I wanna know is this normal for the s23fe and can any s23fe user please confirm?
2 Comments
Tendai777
Can you not shut it off from the settings
kemren
Well I mean I do want the haptic feedback too but quick update it seems that the s23fe models are just built like that as I tested on many of those models and everything seems to be working just fine
