maheshtidhaniya
05-16-2022 08:42 AM in
My s22 ultra has serious battery drain issue 15% battery drain at night in stand without using the phone
Does anyone facing the same issue
15 Comments
- « Previous
- 1
- 2
- Next »
JithinAjith
05-16-2022 11:22 AM in
Use 2G only mode
LuciferMornings tarr
05-16-2022 11:44 AM in
If networking coverage is bad it will drain too much. I have only about 4-5% over night drain on 4G. I usually put my phone on WiFi & switch off 4G using Bixby routine
Roshan5
05-16-2022 07:51 PM in
Check Battery Settings
SubhajitDasgupt a
05-16-2022 08:42 PM in
My friend exchanged s22 with s21+ due to a small battery in s22
samfan156
05-17-2022 08:49 AM in
Depends upon the carrier as I saw in the screen shot the network is very bpoor in your area soo change your Sim card perform a hard reset
1Awatar new
05-17-2022 02:27 PM in
Galaxy SSamsung Galaxy S22 2nd May 2022 update addresses battery draining read more : https://www.sfcnation.com/samsung-galaxy-s22-2nd-may-2022-update-addresses-battery-draining/
- « Previous
- 1
- 2
- Next »
