Screen problem s22 ultra
(Topic created on: 05-23-2024 06:00 PM)
Ackshay454
Beginner Level 4
Got screen problem on my s22 ultra
6 Comments
Not applicable
What screen problem are you experiencing? Let me guess, a green line ..?
Ackshay454
Beginner Level 4
Yes green line
Not applicable
Sorry, my friend, I don't have a solution to this problem. I leave this for somebody else to help you solve that problem. Alright?
Ackshay454
Beginner Level 4
Okay thanks
Tendai777
The Greenline issue is a hardware problem that requires the phone to be opened and repaired by a technician. It is likely that the AMOLED display will need to be replaced, which can be expensive. A cheaper LCD alternative is available, but it is not as durable and may cause the phone to use more power on AOD.
Jacques88
Just my experience and opinion on my S22 Ultra it has cracks in both corners. After a previous update to UI6.0, it developed a green line at the bottom across the phone horizontally, not because the glass is cracked but of the update. I'm getting the whole screen replaced at a certain point as I don't use the phone anymore but I knew it was the update.
