Samsung s9+ battery issue
(Topic created on: 07-29-2019 08:31 PM)
crunchynapkin
Since updating to andriod pie when ever phone gets 20% it dies within 5 sec, however till 20% battery is ok around 5hr sot but when it comes to 20 percent dies within 5 sec does anyone facing this issue in s9+ or any other Samsung devices?
9 Comments
chinkychinky
Beginner Level 3
no
FarhanNavas
no issue with my S8
jas19
no
aravind63
yes bro .....I'm also facing the same problem for s9 plus....
crunchynapkin
how you are dealing with that did any fix?
aravind63
I did software update in service center ....slight improvement in battery discharge but not fully satisfied....
crunchynapkin
thanks for info
mkaif22
i have the same problem
mkaif22
did factory reset but still the same.. calibrated battery (100% charge to 0% and vice versa).. no improvement..
