Samsung s9 battery drain issue
(Topic created on: 05-22-2022 02:14 AM)
Sulman96
I have samsung s9 i saw issue of battery draining too fast please anyone can tell how can i get good battery life.I saw in samsung members app my battery is in normal condition is i change my battery to get good health are stay with this ?
5 Comments
Don't use heavy apps like YouTube tiktok Facebook location then see 30 to 4p% good results
If not give food results then your battery life is dead replace it
GoldenXPK
Battery health deteriorates over time even if it's not being used. Your phone is 4 years old now. Try replacing the battery or if possible upgrade to a newer model.
Sulman96
It is not possible to upgrade because my s9's condition is very bad its only work good.you can help me to tell that how i can get good battery.it's standby mod can also decrease the battery quickly.
Sulman96
Please See this & tell me i can change the battery or not.Screenshot_20220522-141830_Samsung Members.jpg
GoldenXPK
You can get your battery replaced from you local market.
If you don't want to replace the battery, you can use Power Saving mode all the time to increase a little bit of usage time. Decrease the resolution to 1080p to further increase you battery.
