Samsung s24 ultra camera problem
(Topic created on: 4 weeks ago)
gauti123
The Samsung S24 Ultra camera is encountering a technical issue that is causing it to behave abnormally when switching between 1x to 3x and other zoom modes. The zoom function is not operating as intended, resulting in inappropriate zooming behavior.
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
