Samsung s24 ultra battery drain problem
(Topic created on: 09-15-2025 08:54 PM)
AVULARaja
Really very bad experience
Samsung s24 ultra very fast drained battery
Really it's so bad for me
Battery🔋 drain very fast
Especially night time I'm full charge phone📱 I'm seeing morning, 22 % down Battery🔋
What is like this without I'm not using😕 overnight
5 Comments
Hi 👋
Sorry to hear about your experience. Battery drain can feel really frustrating, especially on a new flagship like the S24 Ultra. A few things you can try:
Check battery usage in Settings → Battery & device care → Battery → Usage. This will show if any specific app is draining more than usual.
Update to the latest software since Samsung often pushes optimizations for battery.
Adaptive Battery & Power Saving → make sure these are enabled to control background activity.
Wipe cache partition (doesn’t delete your data) after major updates; it can sometimes fix abnormal drain.
If the drain continues even after these, I’d recommend running the Samsung Members Diagnostics → Battery test and sending an error report. That way Samsung can check logs and push a fix if it’s software related.
samasungs24ultra
Really samsung s24 ultra have battery drain issues my also same i just buy new from samsung store i use 2 3 months only to fast battery drain i did everything what they suggest to do still same this 5000mah this only they show us normally others phone have only 4000mah but that phone to last long battery but this i don't know what i do for this
AVULARaja
Thank you Samsung for solving my problem with one UI 8
1n_ad
Explain what the solution was, please
AVULARaja
My battery draining is solving
