Ygritte
04-24-2025 04:57 PM in
Hey guys, is it just me? After the update the tap-to-lock is a little bit delayed?
7 Comments
Nibin_Acl
04-24-2025 05:00 PM in
me tooo .... Tap to lock delay
Ygritte
04-24-2025 08:28 PM in
Unlike before right?
Hookesultra
04-24-2025 05:11 PM in
Same here
Ygritte
Yeah, its delay bruv.
Usmee
04-25-2025 07:00 AM in
The issue can be solved by using QHD resolution for your screen, in FHD resolution the issue is still there. Hope they fix it in future updates
Ygritte
04-25-2025 08:20 PM in
How?
Usmee
04-25-2025 08:26 PM in
Go to settings display and use QHD resolution for your screen and then check your phone it will be fine
