Samsung s23 ultra battery life with adaptive refresh rate
(Topic created on: 11-15-2023 06:46 AM)
AddiP
Hi everyone,
I am concerned that I might have a faulty s23 ultra. It's battery life seems not great. But when I look online everyone raves about the battery life.
If you have a Samsung S23 Ultra, please send a screenshot of you battery usuage?
So I can compare to see if it is possible I got a faulty unit...
Please also leave your settings along with the screen shot🙏 (performance profile, screen resolution, screen refresh rate, battery saver)
Thank you!
9 Comments
Bensavy
Hi this is my usage on my s23 ultra .....no powersaver all maxed out.Screenshot_20231115_081031_Device care.jpgScreenshot_20231115_081021_Device care.jpg
AddiP
Can you send your usuage on a full day? Preferably one where you used your phone a lot
Bensavy
Performance profile light
Bensavy
Some more settings i useScreenshot_20231115_081658_Settings.jpgScreenshot_20231115_081635_Settings.jpg
AddiP
I've installed the November security patch... I don't have any other updates
JstLykDt
Battery issues came with Android14 and Google had addressed that with an update, I'm sure Samsung will be releasing a security update very soon.
DeeNxo
@JstlykDt After reading this. I'm not in a rush anymore to update to android 14 anymore 👀. I think I'll wait 6months more when they release it for my device, so they can update everything right n fix issues.. thanks 🫱🏻🫲🏽
JstLykDt
Don't wait for 6 months, other devices yet to update to Android 14 won't have a battery draining problem anymore.
