AlexDcosta
01-12-2022 01:03 PM in
Anybody faced random local sim1 mobile data connection drop when using dual sim in s21 ultra especially with sim2 on international roaming
7 Comments
dilshan1
01-12-2022 01:12 PM in
Yes
dilshan1
01-12-2022 01:14 PM in
Still not figure it out why
AlexDcosta
01-12-2022 01:17 PM in
Are you having data drop issues even when using both local sim cards?
dilshan1
01-12-2022 02:16 PM in
Yes but my one sim is roaming
And if u set 4 g mode u can use both sims
AlexDcosta
01-12-2022 03:43 PM in
I dont seem to have drop issues when using both local sim cards but have issues when using one roaming
dilshan1
01-12-2022 05:06 PM in
OK so I think I have to remove roaming sim
AlexDcosta
01-15-2022 09:41 PM in
Try setting the network of the roaming sim to 2g only and check. I set mine, data seems to work fine
