Samsung s20 fe battery drain fast
(Topic created on: 02-12-2021 01:02 PM)
ahmedyousry2
The battery drain very fast using 60 hz , put all apps in deep sleep , turn on power saving . Turn off all visiabilty enhancment .
If battery 100% it will take only 5 mintues to be 99% and 11mins to be 98 %
What else i should do !?
7 Comments
ShaahidSampan
have you tried Adaptive power saving mode. Once the usage patterns are saved it will automatically turn on and off power saving mode to save battery in an efficient way.
ahmedyousry2
i did all but there is something wrong in battery in samsumg .
maybe screen take alot of power or processor !
i used another mobile for half hour using facebook and battery still 100%
ShaahidSampan
I suggest if the phone is under warranty to get it checked at a Samsung service center! 🤞🏼
ahmedyousry2
yes it is under warranty i just bought it but it is very bad battery i can see alot of people complain
Alharban
If you Google it you will see that it is a real issue almost everyone with Exynos chip S20 and 21 is facing. Samsung service centers will do a reset and give you some advices how to reduce the battery redemption, which is not helpful.There is a real problem and they don't want to admit it.
ahmedyousry2
mine is snapdragon , it is about software drain battery and heat
i cannot imagine what will happen when temprature become 50+
Samsung_specialist
Hi there,
Sorry to hear. Please bring your device to a Samsung Service Center to help resolve the issue and have the device checked out by a technician.
Find the nearest service center to you online.
