04-11-2022 11:26 PM (Last edited 04-11-2022 11:29 PM ) in
Galaxy SSolved! Go to Solution.
3 Solutions
04-11-2022 11:46 PM in
Galaxy S- Mark as New
04-11-2022 11:58 PM in
Galaxy S1. use brightness level between 0%-30%
2. turn off Auto rotation
3. If you use mobite data change to the wifi
4. turn off bluetooth and some unused options.
5. if you have lot of unused apps, so uninstall apps
If my comment is helpful for you accept my comment as a solution 🙂
04-12-2022 05:12 AM in
Galaxy SIf not alternative would be replacing the battery.. click these link to get a original replacement
Check out Samsung S4 I9500 Battery Samsung S4 Battery fo...at 32% off!Rs. 2,550 only!Get it on Lazada now! | https://www.daraz.lk/products/samsung-s4-i9500-battery-samsung-s4-battery-for-galaxy-s4-i9500-i9505-...
Check out Samsung Galaxy S4 Battery!Rs. 2,000 only!Get it on Lazada now! | https://www.daraz.lk/products/samsung-galaxy-s4-battery-i104596654-s1011511829.html?dsource=share&la...
If you found my comment useful, kindly click on the 3 dots and select "Accept Solution"
Thank you so much 😊
04-11-2022 11:48 PM in
04-12-2022 01:39 AM in
04-12-2022 04:08 AM in
Thank you so much 😊
