Samsung S7 Edge Battery Draining!
(Topic created on: 05-20-2016 05:11 PM)
Adnan1
I have recently purchased s7 edge, I thought this time they will improve the battery but it's still the same. I called retailer to change the device, and they are not doing it. kindly tell me why is that? I have to charge it every time and I can't take the phone for a long time. what's the solution???? 😕
4 Comments
tony5
if its new and you havent downloaded any unknows app it should not do that definitely thats a phone issue
tony5
i have more than a dozen apps and its battery life is amazing
nappu
my battery too its draining fast
MiDoSaMi
Over loading phone with downloads and install processes can lead to battery drain, if u use it decently, it wouldn't, also check wuts eating it, and force close or Uninstall if necessary
