03-14-2024 11:40 AM in
Galaxy S- Mark as New
03-14-2024 01:07 PM (Last edited 04-10-2024 03:46 PM ) in
Galaxy S1. Restart Your Phone: Sometimes, a simple restart can help resolve temporary software glitches.
2. Check for Rogue Apps: Even though you haven't installed any new apps, it's possible that an existing app may be misbehaving or causing the issue. Check your battery usage stats to see if any particular app is consuming an unusually high amount of power.
3. Clear Cache Partition: Clearing the cache partition on your device can sometimes help improve performance after a software update. This won't delete any personal data, but it can clear out temporary files that may be causing issues.
4. Factory Reset: As a last resort, you can try performing a factory reset on your phone. This will erase all data and settings, so make sure to back up your important data before proceeding. After the reset, set up your phone as new and see if the issue persists.
If none of these steps resolve the problem, you may need to wait for a subsequent software update from your device manufacturer to address the issue. You can also reach out to their customer support for further assistance.
03-14-2024 02:34 PM (Last edited 03-14-2024 02:34 PM ) in
03-14-2024 02:43 PM in
03-14-2024 02:48 PM in
03-14-2024 04:05 PM in
03-15-2024 10:49 AM in
03-14-2024 10:48 PM in
03-14-2024 02:19 PM in
03-14-2024 02:38 PM in
Galaxy SDo try to clear cache partitioning, i just did it, maybe it will help a little with the heat and random glitches
