abunitith
3 weeks ago in
Please share with me how to check battery life on Samsung S24 Ultra
3 Comments
MOQBALI
โ
3 weeks ago in
You can check the battery life (battery status) on your Samsung Galaxy S24 Ultra by following these steps: ๐
Open the "Settings" app on your phone. โ๏ธ
Scroll down and click on "About Phone." ๐ฑ
Click on "Status Information." โน๏ธ
Look for the "Battery Status" option, which will display if the battery is "good" or needs maintenance. โ
abunitith
3 weeks ago in
Im asking battery ๐ Life span remaining
Samsung_special ist
2 weeks ago in
Galaxy SThank you for contacting us regarding your Galaxy S24 Ultra. To check the battery life and health of your device, please follow the steps below:
To Check Battery Usage:
- Go to Settings.
- Tap Battery and device care.
- Select Battery.
Here you can view battery usage by apps, screenโon time, and charging history.
Check Battery Health Samsung does not show detailed battery health directly in the settings, but you can check it through the diagnostic tool:
- Open the Samsung Members app (preโinstalled on your device).
- Tap Support at the bottom.
- Select Phone diagnostics.
- Choose Battery status. This will show the current health and performance of your battery.
Tips to Maintain Battery Life:
- Use the original Samsung charger and cable.
- Avoid keeping the phone plugged in for long periods after reaching 100%.
- Enable Adaptive battery in Settings > Battery and device care > Battery > More battery settings.
- Keep your device software updated for the latest optimizations.
