Samsung S23 ultra battery drain too much
(Topic created on: 06-18-2024 06:54 AM)
IamVimal
Hello,
I am writing to bring to your attention an issue I have been experiencing with my Samsung S23 Ultra after the recent 6.1 update. I have noticed a significant increase in battery drain, which is causing inconvenience and affecting my overall user experience.
I kindly request that this issue be addressed and resolved in upcoming updates. Additionally, I would appreciate any guidance or alternative methods to mitigate battery drainage on my Samsung S23 Ultra.
Thank you for your attention to this matter.
4 Comments
syed_asad1
Hey, you should probably turn on battery protection.
Zarrar26
Have you noticed any unusual drain by an app in battery management?
FahdR
Yes media picker
Fvidal
 Has anyone been able to find a solution to the problem? I've already given the factory reset, but it didn't work. Any suggestions?
