11-23-2024 01:14 AM in
Galaxy S- Mark as New
11-23-2024 06:38 AM in
Galaxy STo better understand the issue, let's try to troubleshoot:
1. *Software updates*: You mentioned you're not sure if the issue started after an update. Check if there are any pending software updates for your device.
2. *Camera app settings*: Ensure that the camera app is set to use the front camera and that the settings are optimized for low-light conditions.
3. *Clean the camera lens*: Dirt, dust, or fingerprints on the camera lens might affect image quality. Gently clean the lens with a soft cloth.
4. *Reset camera settings*: Try resetting the camera app's settings to their default values.
If none of these troubleshooting steps resolve the issue, it's possible that there's a hardware problem with the front camera.
Considering the S23 Ultra's premium pricing, it's reasonable to expect better performance, especially from the camera. I recommend visiting a Samsung authorized service center for further assistance. They can inspect your device and provide a more detailed diagnosis.
Remember to also share your concerns with Samsung's customer support team, as they value customer feedback and may be able to provide additional guidance or support.
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
11-23-2024 07:39 AM in
11-23-2024 07:56 AM in
11-23-2024 09:11 AM in
11-23-2024 09:17 AM in
11-26-2024 11:45 AM in
Galaxy SDear Samsung Member,
Please perform the following steps to resolve this issue:
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
● You can reset your device by following the steps:
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
