Samsung S21 Fe overheating issue
(Topic created on: 02-01-2022 02:05 AM)
Zuhairak
I am facing overheating issues with my S21 Fe.It becomes really hot after using for sometime.Anybody else facing the same issue?If any tips do let me know.
9 Comments
Umaerkhaan
Zuhairak bhai aap Backup bana ker reset kero hard reset ya step by step Background running app ki cache clears kero or Resultion ki settings main check kero
Waqarhssn
No need to reset the phone its normal s20 fe also get heatup while using
AhmadJs69
Sari apps ka background usage bnd kro.
arslan13571
guys how to redeem the pre book gift on s21 FE
Zuhairak
Go to benefits tab there you will see a s21 fe early bird voucher
Zuhairak
This will be shown if your phone is pre booked.Screenshot_20220201-213055_Samsung Members.jpg
HmzaMir
Zuhairak bro I also pre booked but I can't see any early bird voucher under benefits section. Could u help?
Zuhairak
Contact samsung Pakistan customer care.I also contacted them and after 2 days i could see the early bird voucher.
HmzaMir
Okay thanks for your time.
