akgfire
01-21-2021 12:03 PM in
Battery consumption of s20 camer's has drastically increased. Please help.
See the power consumtion. 1% consumption for 1 photo.
16 Comments
- « Previous
- 1
- 2
- Next »
Notadeveloper
01-29-2021 07:40 PM in
Strange then, not facing it on my S20+
akgfire
01-29-2021 07:51 PM in
check it..if possible. else fix it. thankyou for the response.
loved this s20. handy and beast
akgfire
01-29-2021 07:53 PM in
i think the images are in hdr mode plus size is much larger than normal images. this might be the reason. and in live focu mode it takes time to blur the background.
ketani72
01-21-2021 12:46 PM in
Camera does consume battery while in use, nothing abnormal.
akgfire
01-21-2021 02:03 PM in
that means it will shoot photos for 2 hrs only
Ehsank
01-21-2021 01:40 PM in
If after update then wait for few days, and as of now perform these below steps;
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable and connect withpc/laptop/type C earphone only for Android 11 )
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
Steps to perform.
akgfire
01-21-2021 02:02 PM in
i did not update any. i m just using it as it was before
- « Previous
- 1
- 2
- Next »
