Samsung S20 FE 5G battery issue
(Topic created on: 02-11-2022 09:55 PM)
Vicky1523
Beginner Level 3
I bought this phone last month only but I'm not happy with the battery. Its draining to the extreme. Suggest me some tips to avoid this.
4 Comments
SHINAN-EpFBz
what's your current battery backup timing
Vicky1523
Beginner Level 3
Less than a day
Mafrek
Did u talk to samsung about it also check ur apps drainage and compare that with online battery life see if the battery at fault or apps u have
Samsung_specialist
Hi,
For assistance, please visit one of our authorized Service Centers to check it for you. You may refer to the link it will guide you to the nearest service center to your location https://www.samsung.com/ae/support/service-center/
