Samsung Keyboard Problem in S7 Edge - After Naught update
(Topic created on: 02-10-2017 10:41 AM)
Tamil
Samsung Keyboard for Tamil language is broken. Found a bug. Whenever we type anything in the middle of the word to correct the spelling or for adding character... the entire word collapses. So we need re-type it again. It is frustrating. This issue started after upgrading to Naught OS.
6 Comments
not only keyboard total android 7 is a big bug for s7edge
DrPushpraj
totally agree wid u bro
Samsung_India_
Thanks for being with Samsung and for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. It appears that there may be a third party app or other program that may be leading to what you are experiencing. Placing your device in safe mode disables all third party apps upon startup, to help determine if the use of a third party app is interfering with your device .restart your phone in safe mode. While your phone is powered off, press the power button to turn on the phone, once you see the Samsung logo appear press the volume down key and hold it until you have completely booted up. Also, the relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
Tamil
This response is not relevant to the main topic.
Is there any option to fix breaking of words while doing correction on Other Language (Tamil) Samsung Keyboard?
or
Do I need to install 3rd party keyboards?
I need word prediction. Disabling that will fix. but need a permanent solution.
Honey111
guys i have FOUND THE FIX but hope it works for you guyz as well .. all u have to do is just RESET keyboard settings and clear the personalised data as well and restart the phone ..
it worked for me .hope it works for u all goodluck
WarriorCbe
how do install Tamil typing
