Samsung Galaxy S21 Ultra Media Storage Causing Accessive Battery Drain.
(Topic created on: 04-20-2021 09:32 PM)
SB1701
Hello,
I just bought a brand new Galaxy S21 Ultra. It's been 6 Days since I bought the phone. From day one I have been facing serious battery drain and heating issues with my phone. At times I even have to charge my phone 3 times a day which is crazy considering the phone has a 5000 MAH battery . In the background it always shows media shortage is consuming battery and there is no way to force stop the media storage. I have even tried resetting the phone twice and even that does not help. Getting is touch with Samsung support also isn't helping. Has anyone else faced these issues and was able to solve the problem. If yes, then please share. Thanks
25 Comments
Miraz79
I have a suggestion
SB1701
That is?
Miraz79
If you have any third party media player you should uninstall it
SB1701
Only Spotify and YouTube music.
Miraz79
Though I am using a midrange Samsung
You should put this service into sleep from the developer option ..but don't stop it
SB1701
Tried finding the media storage option but it's not visible.
Miraz79
Sometimes it occurs due to having some unnecessary apps prolonged.
Disable or turn on the ADAPTIVE BATTERY and PUT UNUSED APP TO SLEEP OPTION from the device care option
SB1701
Both of them were already turned on.
AMPK
Expert Level 3
This happens on too much of background operation and your AI is not tuned which happens only after one week of use. Stop background ops. Switch on data saving mode. Next switch off internet in the night. This helps. For me battery usage is zero in the night.
