Samsung 45W Dual Port Car Charger (EP-L5300)
(Topic created on: 03-25-2026 08:15 PM)
smokin
Whether you’re commuting or on a long road trip, this charger ensures your devices stay juiced up at top speeds.
​Here’s why this is a must-have for your vehicle:
🚀 Top Features & Pros
  • Super Fast Charging 2.0: The dedicated USB-C port supports up to 45W, making it powerful enough to fast-charge the latest Galaxy S-series phones, tablets, and even some laptops.
  • Dual Port Versatility: No need to choose between devices. It features a 45W USB-C port and a 15W USB-A port, allowing you to charge two devices simultaneously.
  • Universal Compatibility: While optimized for Samsung, it supports Power Delivery (PD 3.0), PPS, and Quick Charge (QC) standards, meaning it works great with iPhones and other Android devices too.
  • High-Quality Cable Included: The box comes with a heavy-duty 5A USB-C to USB-C cable, specifically designed to handle the high-wattage output.
  • Compact & Safe: Its sleek, low-profile design fits seamlessly into most car power sockets, and built-in safeguards protect against overcurrent, short circuits, and high temperatures.
Bottom Line: If you have a device that supports 45W charging, this is one of the most reliable ways to get "wall-outlet" speeds inside your car. 🚗💨
2 Comments
Good that this comes with proper cable. No need to buy separately.
Yes 🔥
