SAMSUNG HAS AN ANNOYING CAMERA SHUTTER SOUND
(Topic created on: 04-05-2025 10:48 PM)
Jeetsen
I think Samsung should improve its camera and Specially The shutter sound, like Apple's, symbolizes a high-end camera. That's the kind of sound it should have. I think Samsung should work on it and replicate the same sound as Apple devices. I think this would be a key selling point for Samsung phones.
3 Comments
mZoOnY
Didn't know that 🤔
Samsung_specialist
We’re truly sorry to hear about the inconvenience you’re experiencing, you may try the following steps to troubleshoot the issue.
1. Turn off Shutter sound.
Navigate to and open the Camera app, and then tap the Settings icon. For the Galaxy S25 series and devices running One UI 7, tap the Quick controls icon (the four dots), and then tap the Settings icon. Swipe to and tap the switch next to Shutter sound to disable it.
If your device does not have this option, please continue to the next step.
2. Use the Volume down button.If you do not have the Shutter sound option, you can turn down your phone's System volume. To do this, press the Volume down button while on your phone's Home screen, and then tap the three dots at the top of the pop-up menu to open additional volume settings. Use the slider to turn down the System volume. You will not be able to hear the shutter if the System volume is turned all the way down.
Jeetsen
Thanks for your reply, but I wasn't referring to disabling or enabling Samsung's shutter audio. I was suggesting that Samsung innovate its camera shutter sound to resemble the iPhone's. This would be a key selling point, increasing sales by replicating the original camera's shutter sound. Is that clear, sir?
