S9 - too low sound of notifications
(Topic created on: 10-09-2018 02:03 PM)
Ros1
We just got a new S9 in Bahrain. There is a very serious issue with the notifications - low sound despite software volume is maxed. Apparently the issue is that notifications are only using the small speaker at the bottom of S9 and not the large speaker at the front.
To the contrary, ringtones and media are using both speakers and sound is decent.
I read in forums that this is common issue in S9, S9 and Note 9.
Samsung please fix this asap for your expensive flagships, or I will return the phone and go Iphone !!!!!
3 Comments
Sahaxp
It is strange that you have so. Everything on my s9 + works very loudly, and notifications and calls.
Ros1
thanks Sahaxp. from what I read is quite common. check out these https://eu.community.samsung.com/t5/Galaxy-S9-S9/Low-notification-sound-s9/td-p/538997 https://forum.xda-developers.com/galaxy-note-9/help/notification-sound-low-mono-versus-t3835205
Ros1
no answer by samsung yet
