guri8751
It's been 7 months since i bought s9 plus exynos variant and battery life seems to be disgusting nowadays. I unplugged my phone at 100% at 7 in the morning and the battery was down to 3% at evening with only 2h of screen on usage. And while playing PUBG the battery drains at 1% per 2 minutes of gaming and phone overheats as well. Please suggest a solution. Thanks!
13 Comments
shiv25
try resetting your device. i have same device and i am getting screen on time of around 5.30-6 hrs with mix of youtube,songs,net browsing and few pubg games too.
you use your phone on high performance? i keep it mostly on power saving mode
guri8751
I got my phone reset from the service centre. But the battery performance is still the same. Almost no change.
guri8751
@shiv25 i use my phone on optimised battery setting.
deepakguptha008
agreed
rp16
get it checked from ther service centre. Tell them to change the battery. Do it before your warranty ends.
guri8751
can i get my whole phone replaced?
rp16
no bro its tough that they will replace its been 7 months. Though ask them for replacement and see what they say
rp16
keep these screenshots to show them the battery drain
rp16
i was recently having such an issue on my note 8 twice they just did software update third time i requested to change the battery and they did.
