S9 Battery Stats
(Topic created on: 02-17-2020 12:57 PM)
SamahKD
After 2 years of use, I am barely getting 2 hours of screen on time and total of 8h of battery life which kind of frustrating.
I need to know if this case is the same for other S9 users or it is a my phone issue.
Also if you can share with me your battery stats i would appreciate.
Thank You
4 Comments
Samsung_specialist
Hello there,
Battery percentage may vary according to the usage (internet, call, video playback, etc..). However, if you feel that the device battery drains quickly when no function is used, please send the device to one of the service centres to discover and fix the problem. www.samsung.com/sa/support/servicelocation/.
SamahKD
Thank you for the reply, I do not have any suspicious applications and I always optimize the device to close any open apps, still getting max 2 hours of screen on time, and normal usage, mixture of WIFI and mobile data, and indoor which means the brightness is not all the way up. I just want to check is this normal for an S9 after 2 years of use, or is it a phone issue of mine.
Thank You
Sahaxp
Samsung certainly made a very uncomfortable schedule for viewing the battery discharge. I have s9 + after updating the screen for 5-6 hours, a day, two days of the phone.
glaasy
after the recent software update I am having the same problem with my S9. the battery is draining very quickly even if all the apps are closed
