SumanB
My S9+ battery reached 25% and suddenly reaches to 5% and then shuts off immediately. What should I do?
12 Comments
MasterFahad
take it to axiom
SumanB
Thanks for the reply. Will they replace my battery or repair it cos its still under warranty.
MasterFahad
They should replace it. I had an A5 (under warranty) which had a swollen battery, I took it to them and they replaced the whole phone and gave me a new phone as they didn't have the replcement parts available.
MasterFahad
or try this ->
-switch off phone
-press and hold power, bixby and volume Up key at the same time.
-once you see the android guy, let go off the buttons
-using volume key, navigate to wipe cache partition, press power button, select YES and then after its done, reboot your phone.
Hope this fixes the issue.
Your data will NOT be lost, Don't worry.
SumanB
thanks will try.
SumanB
just did it. thanks. how will i notice that this technique is really working?.
MasterFahad
Your problem should be fixed
MasterFahad
wait until your phone reaches 25% and check if the same problem occurs again. If not, then it is fixed else go to Axiom, they should do something about it as it is most likely a hardware issue.
SumanB
