S8 plus huge battery drain after one ui android pie update
(Topic created on: 02-26-2019 03:30 PM)
Bro96
After seeing an one ui update ...was so happy and installed it today ..then I found a sudden battery drop from 95 to 50 % even when I doesn't use my phone ie.idle...I updated and used the phone only for making calls that too not much ...but found a massive drain in battery .....kindle fix this issue as soon as possible .....
2 Comments
Not applicable
battery is draining fast in stand by mode too.. even internet is off
admin_
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members BETA App ->BETA Feedback > Send Feedback > Error reports > collect log file > Attach).
Be sure to hit ♡ when you find an answer that works for you.
