Swapnil76
02-14-2018 02:50 PM in
After updating my s8 to oreo i cam see that there is drastic change in battery performance its draining too fast. Does anyone also facing the sw iasue.
7 Comments
sammobile001
02-14-2018 02:53 PM in
no.
Not applicable
02-14-2018 03:02 PM in
no
karanS23
02-14-2018 03:17 PM in
Format your phone after updating. I did it yesterday and now the battery life is fine on my S8+.
roshini96
02-14-2018 04:08 PM in
open this👉 http://bit.do/samsung-app-link-download
sahilRana
02-14-2018 06:42 PM in
hmmmmmmm
panisai
02-14-2018 08:27 PM in
yes same problem
admin_
02-17-2018 10:15 AM in
Thanks for reaching out to the Samsung support communities! We do apologies for the issue you are facing in the device after Oreo update. The relevant department will serve you better/speedily, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
