RickyS10
I am having this issue post Oreo update and the latest update claiming Camera improvement also didn't fix it. I am using Exynos variant of S8.
12 Comments
vicky1361
battery drain ka issue h ya nhi aapke s8 m bhai mere s8 m battery drain ho rhi h or heating issue or fast charging problem koi solution ho to batna
v7
कोई solution नही है भाई. S8 खरीदना galat साबित हुआ. Battery life दिनोदिन बदतर होती जा रही है. Heating issue भी है. Latest update के बाद भी कोई change notice नही आता.
riyaj4455
fast charging nahi hota hai
Romba
reset app preferences and see.
woh kashe karni h
Romba
what?
admin_
Thank you for being with Samsung and sharing the concern. We would request you to provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports) so that your concern can be resolved soon. Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
kartik909
poor slow motion function
vishnu10
Check if you are using power saving mode while recording show motion videos......I had the same issue but when I tried to record in normal mode, it turned out fine
