S8 S8 PLUS DISPLAY PROBLEM
(Topic created on: 11-05-2019 02:07 PM)
prakashmj
Hi guys any one notice after android pie display quality of S8 plus is degraded as u can see in above picture black noise is clearly visible in sky and her jacket...u can also check in your phone by this pic in Instagram id : jaiswalpragya if u also notice or compare with other Samsung phone even it's lowest quality phone like M30 also show much better then S8 plus....
Like u can see in below picture from other phone with same picture in Instagram of her... plus tell me or reply with your screenshots as u can see this or not....
Reply with your screenshots... if u use S8 plus
Noise seen in only S8 plus other than it's seem perfectly if your display is good.
6 Comments
Not applicable
pie android is its self a degrade
kukuu
bro galaxy a50 also face the same problem after october security update
prakashmj
send me screenshots
KP01
Samsung force us to change mobile every year.. for that they give bad software update to degrade performances , smoothness etc.. it's a business policy guys
KP01
Total android pie update for samsung is tremendously bad.. which effects all new and old phones.. main degrade after software update is battery backup.. oneplus does good bt samsung is reverse of that
maher
that's not Samsung fault. That's because of oled display when black background come pixel turn completely off. You can check in every oled phone. Also you can check on YouTube also try searching completely black background
