S8 + DISPLAY PROBLEM BLUE DOT
(Topic created on: 05-03-2017 06:08 PM)
syedhisham
I got a s8+ pre ordered here in the UAE. Since recently I have noticed a blue dot near the centre display with no movements while using the mobile.
Is this a pixel problem or a software issue?
Thanks
11 Comments
Subzero355
does that "blue Dot" also appear during the boot up screen?
syedhisham
I have in fact done a screen test through applications. It seems like there is a dead pixel.
syedhisham
Yes it does. stays until the phone goes off again
Subzero355
as long as it's not Black, you can still recover it, in your case, it's a Stuck pixel, try this app and hopefully it'll​ recover https://play.google.com/store/apps/details?id=com.aiuspaktyn.pixelfixer
syedhisham
Thanks a lot. it seems like it worked. shall update u if any changes
Subzero355
You are welcome, I'm glad to help, it should not occur anymore, however do let me know in case something happens.
syedhisham
unfortunately it has come back. It seems like a dead pixel. Gonna have it checked with Samsung. So disappointing to have a new phone repaired
Subzero355
that's sad to hear, but I think you should be able to replace the phone if the phone is still not 14 days old
syedhisham
got it on 16april I guess. let's hope for a replacement. first Samsung and it's a sad start
