S7 edge downgrade
(Topic created on: 11-26-2017 10:16 AM)
SagarSapte
I want to confirm that is downgrading possible after the october patch update. Coz samsung has restricted downgrading for some devices
6 Comments
TechnoMaster
no it is not possible.. can brick the phone
Ysh
do yourself
admin_
Thank you for sharing your concern. We would like to inform you that Samsung never recommend or provide downgrading of OS after update. You can only update your device using smart switch or FOTA. Be sure to hit ♡ when you find an answer that works for you.
Phoenix7
yes you can...
Hathim214
malayalii
Phoenix7
yeah....
