Sidmarker
06-09-2017 08:53 PM in
Now sometimes my jio net speed gone worst..now it doesn't even open any site..Is this is a network fault or cell..?
7 Comments
Imranphysics
06-09-2017 10:34 PM in
Obviously network issue, jio is a very unstable network
Sidmarker
06-09-2017 11:03 PM in
but when I check others jio net speed they work fine at the same time..
theragingbull
06-10-2017 05:02 AM in
its a problem with all samsung phones that have may 1 security patch.problem is present in j series,a series,s series
Imranphysics
06-10-2017 08:18 AM in
I have May patch in S6 but no network problem
theragingbull
samsung must provide update
Sidmarker
06-10-2017 08:44 AM in
is there any solution of this or I have to wait for next update..!!
admin_
06-10-2017 09:51 AM in
"Thanks for being with Samsung and for sharing your.
Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. We would like to suggest you kindly follow the below mention steps to overcome the Issue:-
1) Ensure that network frequency of your device should be selected on Auto-mode.
Menu>Settings> Connections>More Networks> Mobile Networks> Network Mode> Select Auto mode (GSM/WCDMA/LTE).
2) Search for the Network Manually as follows:
Menu> Settings> Connections>More Networks> Mobile Networks> Network Operators> Select Manual Search.
3) You may check by exchanging the SIM in SIM slots.
4) Insert different SIM card in your mobile and check if the issue is resolved or not.
If still issue persists then we would suggest you to once contact with your service provider".
