S7 Edge Issues
(Topic created on: 09-02-2019 02:46 PM)
Rayhanur
How can I improve my battery performance? Day by day battery quality is declining?
One other point need to know that how can I use slow motion camera feature by using s7 edge camera?
And how can I unlock my device only by using fingerprint without using home button key or power key?
9 Comments
SneekND
May you need to change the battery to new one, the device is 3+ years old.
Rayhanur
Yes.I think so
xdgone
1. battery replacement
2. press home key once and hold your finger
3. slow motion from camera look the snapshot
Rayhanur
Thanks for sharing. but is there any option to unlock just placing finger in fingerprint sensor without press home key once
xdgone
s7 edge finger print is not designed such
xdgone
You can use guesture wake up screen feature . this will help not to use power key or home bottom press for unlocking with fingerprint. But this has a limitation , it works only if handset is on a plane surface and screen is upward facing
setting can be found in
Go to: Settings > Accessibility > Dexterity and interaction > Easy Screen turn on and toggle ON.
Rayhanur
ok.noted
Navi1
use one sim.
uninstall or disable extra apps.
turn off location nfc sync. rotation options.
restart phone weekly.
dont use phone while charging
Rayhanur
Ok.noted
