Highlighted
Hi all, I recently bought a s7 edge black onyx 935FD and today cleaning the device find that there is a separation of the edge display and the aluminum bezel side of the volume keys. Through this space you can see the continuity of the keys since it is approximately less than 1mm, curiously that space only appears from that side since everything is normal on the ignition side. Has anyone had this? It is normal?. And got into the water and worked properly.
3 Comments
Highlighted
no man.thats not normal.
if have space refuse water resisstant.you can go samsung supporters shop for your problem.
Highlighted
This is not normal. There is no space anywhere between the edge screen and the bazles
Highlighted
You must have been using a case. Go naked. This is a common complaint with tight fitting cases.
