OsamaOdeh84
06-14-2016 04:14 AM in
after marshmallow update silent mode is not working properly notification sound is coming sometimes even if my phone is on silent mode.
BVB
06-14-2016 12:09 PM in
you can try the device on the safe mode and check the device. you can activate the safe mode through the following steps:
- restart your device
- when it shows samsung logo, you have to press and hold the volume down key till you reach the safe mode
- you can try and observe the device for two or three hours. if the device working fine, so this issue caused by some third party apps. so you have to check your apps
