S26 ultra maximum privacy display issues
(Topic created on: 03-07-2026 01:18 PM)
smdrafik
I bought the Samsung Galaxy S26 Ultra a few days ago because it is a flagship phone with many advanced features. One of the features I was most interested in is Maximum Privacy Display.
However, when I enable this feature, the screen shows a white shadow effect, and the display is not clearly visible. This makes the feature difficult to use and affects the overall experience.
This feature is very useful for privacy, and it is one of the reasons I chose this phone. But right now it feels disappointing, especially after spending money on a premium device.
I hope Samsung will acknowledge this issue and release a fix through a software update as soon as possible so users can properly use this feature.
13 Comments
merxis
for the price,it's disappointing
smdrafik
The first pic is normal mode and the second one when I use privacy display wI3bRf0HaL.jpggjHhnettDu.jpg
neuronalbit
Beginner Level 4
I am also very surprised that when the “Maximum privacy protection” option is activated, the display appears significantly brighter not only when viewed from the front, but also from the sides, and the color saturation is reduced or flattened. This effect is not visible in Samsung's official product showcase videos or in various other videos (e.g., https://youtu.be/BmAM7mygKp0). Could this be a bug? I would like to see this fixed, otherwise I am very disappointed with the feature.
For more in-depth tests, see https://www.lttlabs.com/articles/2026/03/01/samsung-galaxy-s26-ultra-privacy-display.
merxis
I guess that's a trade off when using privacy, at least you can turn it off
smdrafik
Yes bro now the day not use that future
Samsung_specialist
Thank you for contacting Samsung and for sharing your detailed feedback regarding the Maximum Privacy Display feature on your Galaxy S26 Ultra.
We understand your concern regarding the white shadow effect appearing when the feature is enabled. In some cases, visual changes may occur due to the way the privacy display technology limits viewing angles to enhance screen privacy.
We recommend ensuring that your device software is updated to the latest version by going to Settings > Software update > Download and install, as updates may include improvements related to device features and performance.
Your feedback is important and helps improve future updates and device performance.
smdrafik
But still i didn't get any updates from samsung.
Samsung_specialist
Thank you for your follow-up and for sharing your experience regarding the Maximum Privacy Display feature on your Galaxy S26 Ultra. We understand your concern about not yet receiving a software update related to this matter.
Please note that software updates are typically released in phases and may reach devices at different times depending on the region, device model, and network compatibility. As a result, some devices may receive updates earlier than others.
In the meantime, we recommend ensuring that your device is set to receive the latest available updates by following these steps:
  1. Go to Settings.
  2. Tap Software update.
  3. Select Download and install to check for any available updates.
Additionally, please make sure that:
  1. Your device is connected to a stable Wi-Fi network.
  2. Your device has sufficient battery charge (at least 50%).
  3. Automatic updates are enabled if available.
If no update is currently available, we kindly ask for your patience while Samsung continues to review feedback and improve device features through future updates. Your feedback regarding the Maximum Privacy Display feature has been noted and is valuable in helping improve the overall user experience.
Maxw99
I'm having the same issue and I just updated
