S25 ultra battery drain
(Topic created on: 10-05-2025 10:32 AM)
Chiven
Hi
Has anyone noticed after the software update the battery drain on the S25 ultra is insane or is it just me🤔
9 Comments
Tumelo159
To be the battery is actually a bit better. It wasn't draining in UI 7 but now it kinda lasts longer.
Was yours having a drain when you were in One UI 7?
Chiven
No battery was perfectly fine id charge it1ce aday ...but after the upgrade to UI 8 it has to be charged 2ce a day
Tumelo159
I think upcoming security updates will fix it and I also don't want to mess up your comment section, I posted something of Clearing Caches and how to save battery, so you can hop in my posts and check it out.🙏
Chiven
Thanks @Tumelo will definitely check it out i appreciate the advice
LeeTee
Beginner Level 3
I am experiencing the same issue
Chiven
So its not just me
LeeTee
Beginner Level 3
Nah, even on standby I lose a lot i hope this gets fixed through some software update 😔
Chiven
@LeeTee ...let hope I'm going to try what Tumelo advised and hope it improves ...
Aubreyj
My battery also drains quickly
