McNulty
02-16-2025 08:56 PM in
I have a Braun alarm clock with a wireless charging pad, and I've been using it for some time with my S23+ with no issues for overnight charges. The phone would feel warm in the morning but not so much that I ever worried about it.
Now I've upgraded to the S25+ and noticed that the phone is extremely hot in the morning, and it seems to have stopped charging because of they as it was only on 77% this morning. Anyone else having similar issues with wireless charging the S25+? Anything I can do about it?
Solved! Go to Solution.
abualzait
02-16-2025 09:39 PM in
You're not alone—several users have reported that the Galaxy S25+ is getting much hotter than previous models when using wireless charging, especially with third-party chargers. Here are a few things to consider and try:
Possible Causes:
Higher Power Draw: The S25+ may have different wireless charging power requirements than the S23+. If your Braun charger isn’t fully compatible with its new charging profile, it might be causing excessive heat.
Efficiency Differences: The Snapdragon 8 Gen 3 in the S23+ was already optimized, while the Snapdragon 8 Elite in the S25+ could be drawing more power or handling heat differently.
Software Optimization: The S25+ is still new, and Samsung may need to fine-tune thermal management and wireless charging efficiency in future updates.
Overheating Safety Feature: Samsung phones reduce or stop charging if they overheat to prevent battery damage. That’s likely why yours stopped at 77%.
Things to Try:
✔️ Use a Samsung Wireless Charger – If possible, test with a Samsung-certified charger (e.g., 15W or 25W Fast Wireless Charger) to see if it behaves differently.
✔️ Check Charging Position – Misalignment on the pad can increase heat generation. Try adjusting the phone’s placement.
✔️ Remove the Case – If you use a thick or heat-retaining case, try charging without it.
✔️ Charge in a Cooler Room – Higher ambient temperatures can worsen heat buildup.
✔️ Turn Off Fast Wireless Charging – Go to Settings > Battery & Device Care > Battery > More Battery Settings and toggle Fast Wireless Charging off to see if it helps.
✔️ Try a Wired Charger – If possible, use a USB-C cable overnight and monitor if overheating still happens.
If the problem persists, it may be worth checking if a firmware update from Samsung improves charging behavior. Let me know if any of these help!
Possible Causes:
Things to Try:
3 Comments
abualzait
Possible Causes:
Things to Try:
Possible Causes:
Things to Try:
McNulty
02-20-2025 07:02 AM in
Thanks for the tip, switching off fast wireless charging worked for me. It now feels warm after an overnight charge but not super hot like before, and I'm getting a full charge
McNulty
02-16-2025 10:04 PM (Last edited 02-17-2025 07:30 AM ) in
Thanks, I'll try switching off fast wireless charging since I almost only use this overnight, hopefully that sorts it
