S25 - When is the battery issue going to be fixed?
(Topic created on: 4 weeks ago)
humongouspeen
There's been a visible drop in battery backup since the One UI 8 update.
Been seeing the threads on here, about how many have been affected. Took a sigh of relief as it cleared the air that it wasn't just my device.
But when is Samsung due to give an update which fixes the issue?
The battery backup was great when I first bought the phone. But right now, I dont think its anywhere close to that.
I'm pretty much forced to put the device on a light performance profile and turn on power saving if I want to the device to last a long time.
9 Comments
Adityadbg07
Don't except ever things good in Samsung because Samsung is L U N D Dhari Nagin 😂
prince2198
S23 here.. I am also facing the same.. after the last 2 os update battery has been bad. I used to get around 6hours of sot on standard and 6.30h on light on sim..and higher on wifi.. but all that's gone now..
prince2198
I had to reset the phone yesterday to get out of the beta block. Battery is doing considerably better. Idle drain was too much. And that has been controlled somehow..and the battery seems to be performing tad bit better. Not suggesting a reset.. but an option worth considering.. also I had tried all the wipe cache bull sh1t.. didn't help much..1759838689083.jpg
humongouspeen
I see. How long ago were the updates on S23?
Remember a few users I know mention that the battery life of the S23 had fallen. This was a couple weeks back.
prince2198
Yes. Same time frame.. also the newer clock (adaptive bulshit😂) doesn't work properly
humongouspeen
Honestly, its a bummer that the phones in the latest line up still have issues like this. If Samsung can't stress test their updates enough, then its best they just dont rollout any updates. Not like the One Ui 8 update made the phone any better. Just minor changes, which made the experience in terms of Ui a little fine tuned. But if such a small change ends up impacting battery, that's concerning. For that matter, no update should ever impact battery!
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
humongouspeen
Guys, stop giving these SOP messages. You know very well after all the user reports and posts in the community that the battery life has gotten bad! Just fix the **bleep** thing instead of giving these suggestions. It is not tough for one to notice that things have gotten bad with the battery, when continuing to use the device the same way they've ever did.
Jerrydon
There will be no fix from Samsung. Mark my words. U can change from Samsung, like how I did.
