S25 Ultra Camera Ring Durability Test
(Topic created on: 02-02-2025 05:07 PM)
A7MaL
Smart phone communities are sharing and spreading the news that S25 Ultra camera ring is not durable.
I really don't understand the logic of testing durability of something that we already know its glued or weld for design not built-in.
And what else you were expected.? These elements are always extra adding for aesthetics
12 Comments
I would understand if the rings are falling off by themselves, but to grab a pair of tweezers or a screw driver and deliberately removing them then complain about the quality doesn't make sense like you mentioned.
A7MaL
Exactly.. It would have weld rather than glued.. But, still not a big deal to make discussion I think..
Ninnjette
If you put lens protectors on your camera lens like I do every time I get a new phone, but decide to take them off the black rings will come with it. You don't need tweezers you just need to try to remove lens protectors which come with little tools it's so easy to get the protectors off that it takes the rings off with it. It shouldn't be that easy to take the camera lens rings off of a $1,300 phone.
amirvirus
  • Yes they are pathetic I experienced the same issue like yours.....it looks really cheap for a flagship
bb91_S23ULTRA
Hello,
It is possible that the rings’ glue would wear out after two to three years and they would pop out automatically. Another thing to notice is that the rings won’t be removed with slight force, you will have to press them with sufficient power to do this.
Please select "accept solution" if my reply helps you.
A7MaL
Yeah.. Removing that is not an easy task as criticized..
On that video phone's back cover also poped due to the force that he put remove it.
bb91_S23ULTRA
Thanks for understanding 😊
bb91_S23ULTRA
Ramaswamy123
I think it is frankly stupid. In the end the phone still put up with his abuse...even if it was a little less....
