S25 Ultra Battery
(Topic created on: 01-26-2026 03:42 PM)
Haider0077
Hi
I use my phone too much and my battery only last 11-12 hours on wifi .. is it my usage or something wrong with my battery ? Any tips to get better results 🙏
5 Comments
خغثعق
خغثعق
كتملي
كتخ
خغثعق
خغثعق
Samsung_specialist
Thank you for reaching out about your Galaxy S25 Ultra’s battery life. A 11-12 hour battery life on Wi-Fi can be influenced by usage and background apps. Here are some tips to help improve battery performance:
  1. Optimize Battery Settings: Go to Settings > Battery and device care > Battery and enable Power saving mode.
  2. Check Battery Usage: In Settings > Battery > Battery usage, monitor apps using excessive power.
  3. Disable Unnecessary Features: Turn off Always On Display, Location, and Bluetooth when not needed.
  4. Adjust Screen Brightness: Lower brightness or enable Adaptive brightness.
  5. Update Software and Apps: Keep your apps and device updated.
  6. Manage Background Apps: Restrict background activity for apps you don’t frequently use.
If the issue continues despite these tips, you can visit an authorized Samsung Service Center for further assistance:
Samsung Service Center Locator
We hope this helps!
