a month ago in
Galaxy S- Mark as New
a month ago in
a month ago in
a month ago in
a month ago in
a month ago (Last edited a month ago ) in
a month ago in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
a week ago in
Galaxy S2. Reduce screen brightness.
3. Adjust display refresh rate to standard mode.
4. Turn off connectivity.
Disable Wi-Fi, GPS, and Bluetooth when not in use.
5. Turn off AOD.
If you like this solution.
Please
Accept as a solution .
a week ago in
Galaxy Sor
Put in deep sleeping which apps not in regular usage.
2. Uninstall extra apps
3. Battery optimization.
4. Closed all background applications
Please
