S25 Ulta Battery Issue
(Topic created on: 02-26-2026 01:46 AM)
Haider0077
Hi everyone My s25 ultra is draining battery like crazy . Even on standby it drop 10% in 3 hours .. i bought a new 45w charger and its even worse .. Really need a solution otherwise will have to change to a pixel or an iphone because my usage is much and my battery drops 30% in just 3-5 hours . Please any solution dont want to change from Samsung
6 Comments
​"Hi Haider0077! That standby drain is definitely higher than it should be. Before you think about switching, try checking your Battery Usage in Settings to see if a specific app is staying 'active' in the background. Also, try switching your Performance Profile to 'Light' in Device Care—it helps significantly with battery without slowing the phone down. Lastly, a 'Wipe Cache Partition' often clears up post-setup drain!"
Haider0077
Hi Smokin . I have checked everything in battery usage no unusual app .. i will try the performance profile to light . And and directions how can i do the wipe cache partition
Also is the 45 w charger from Samsung??? If yes then it should not give u that issue
Riyadbader
I have the same problem with battery,
AftabOllah
Try to factory reset...
Samsung_specialist
Thank you for contacting Samsung.
Higher battery consumption may occur temporarily after device setup, software updates, or due to background system optimization. Kindly follow the steps below to improve battery performance on your Galaxy S25 Ultra:
  1. Check battery usage
    Settings > Battery > View details and review background activity
  2. Enable power optimization
    Settings > Battery > Power saving > Enable as needed
  3. Adjust performance profile
    Settings > Battery > Performance profile > Select Light
  4. Update device software
    Settings > Software update > Download and install
  5. Clear system cache
    Power off the device
    Press and hold Volume Up + Side key
    When the recovery screen appears, select Wipe cache partition
  6. Restart the device
If required, the device may need inspection. You can locate the nearest service center using the link below:
https://www.samsung.com/ae/support/service-center/
For additional assistance, please visit:
https://www.samsung.com/ae/support/contact/
